About 2 months ago I purchased a used Z781 with the injected Kawasaki, the machine had 100 hrs on it. At first the only problem I had was when releasing the parking brake and moving the arms in to move the engine would die. Pressing the brake several times and restarting the mower it would then work correctly, and this doesn’t happen every time, most of the time it works no problem. My dilemma started last week, I have put 30 hrs on the mower since I got it, all of a sudden the mower started cutting out and surging. I thought at first the fuel filter may be clogged as it appeared original. I then changed the fuel filter, air filters, and plugs, no change. As long as I keep the rpms under 2500 it runs and mows fine, but turn it up and the cutting out and surging starts. Could this be the throttle sensor/controller?
