It first started out by me having to turn and hold the key in JUST THE RIGHT SPOT to get it to fire right up. Now the key, no matter where I turn and hold it at, will not start the tractor now. I discovered how to 'jump' the starter with a piece of wire and that's working fine for me but I need others to be able to use the tractor too. I replaced the key cylinder thinking that was causing the "hold the key in JUST THE RIGHT SPOT" symptom but it still won't start with the key now. Any other suggestions as to what could be causing this issue?
2019 L3301 HST w/ circa 300hrs.
