Wider R4s on L series.
Rokee95
68
Round Hill, Virginia
I came across a pair of front tires and wheels for the front of an L39 L45 or L47 tlb.
They're 27-10.50x15.
The rim offset is centered.
I put them on my L3800 in place of the standard 27-8.50x15.
I like the increase in with, and the OD of the tire is roughly the same.
I'll see how they work.
Sent from my XT1585 using Tapatalk
8,197
2 things to consider:
When you move the offset out you greatly increase the stress on the axle and joints, it will cause you issues down the line.
Close in OD doesn't really cut it on a mechanical 4wd system, changes in the RC will create bind and wear on parts that shouldn't.
2,888
No helpful comments on the tires here, but dude, I love your mass quantities of shelving!
Rokee95
68
I appreciate the tips of caution.
Both tires are side by side the same height. So gearing is unchanged.
The wheel hub is centered in between rim. Zero offset.
The original tires are negative offset.
With zero offset I don't worry about unusual loads on axles.
The only issue I foresee is the positive camber built into the axle.
Fortunately the tire rests on the ground about the same as the original one did.
Rokee95
68
No, I meant I couldn't offer any helpful comments. Sorry I wasn't clear.:)
No problem.
I can't offer any comments either yet.
I haven't tried them out yet.
I thought people with R4s might want to know of an alternative for flotation in Sandy soil, so I posted the suggestion of these.
tiredguy
B3030 HSTC,B2781 51" front mounted snowblower,60" MMM
Jan 21, 2010
301
northern lower Michigan
Please let us know how they worked out down the road and actually sooner
let us know whether or not you've had any binding problems with the possibility
that Wolfman had brought up.
The width difference axle load wise won't show up right away IF there is any
issue with it all being a wider tire. Sounds like you're comfortable with the
offest/inset bringing the tire and wheel in closer so the effects of the width
may not effect it wear wise. Only time will answer that question of course.
Looks awesome!
Al
Rokee95
68
Looks awesome!
Al
Thanks AL.
I won't be able to give feedback on them, as I was allowed to try them out by a local dealer.
They were awesome looking, and I am all about adding the extra width, but after boiling it down in my head it wasn't wise to spend the money when the original tires are so new.
I took them back off and reinstalled the original wheels.
However, if there is anyone who needs a little width, and prefers the flotation with R4s these are an option for them.
It would be an easier tire on the lawn too if you have soft soil areas like many places around me do.
Rokee95
68
That trailer would nearly be worth more than the tractor...
Nice rig...
Thanks luketratts!
I put a lot of effort into that trailer after I bought it used.
Not many people appreciate trailer mods or take much interest so I appreciate you taking notice!
6,334
Rokee - like Lil' Foot said - I'm absolutely enamored with the shelving!!:cool::D
At my place, I wrestle with organization all the time! Usually DISorganization wins!
Rokee95
68
Thanks, but I can't take compliments for all the shelving or the other stuff in the garage.
Wish I could but it belongs to my coworker who was nice enough to let me keep my tractor and trailer there for the winter.
I've been in the process of moving and building on 10 acres.
That's why all my posts have been pics of everything on the trailer.
Soon that'll change.
6,334
Well, tell your coworker I'm envious!
Best wishes with your building project!:)
Sammy3700
L3800HST,524Loader,BH77,Landplane,Disk,Mowers and more
Feb 20, 2012
439
Red Springs, NC
I like the wider tire idea also. The trailer is top of the line, I noticed in one of his previous post he always has the pallet forks. Any one else see them? Great idea!! He also has a super nice set of remotes on the rear!!
Rokee95
68
Thank you Sammy.
I did a bunch of homework on trailers, as they became another hobby of mine.
My dad had lent me a Sure Trak and needed it back, so I searched for one for myself.
Compared all the brands and I liked the Cam Superline the best.
While looking for one, and considering ordering one, I found one in PA that was bought and returned after the buyers track loader wouldn't fit without scrubbing the fenders.
I brought it back to VA and removed the decking, stained all sides, added d rings, added another spare tire carrier under the deck, added the ramps it has on it.
Maybe I should post it in "off topic?"
I didn't realise my trailer would generate interest.
Sammy3700
Feb 20, 2012
439
Red Springs, NC
I like looking at others ideas, I built my 27' flat bed goose neck with two 7000 lbs axles and a 10 ton goose neck dump trailer. Wish I could post pictures of some of my toys. However I like seeing what others have built.
Rokee95
68
That sounds like a cool trailer!
It's even more cool when it's home made and customised to suit your needs.
Is there anything I can help with for learning how to load pictures?
It took me a while to figure it out, and I'm no expert, but if I can help let me know.
Myself and I'm sure everyone else would enjoy seeing your project and fruits of your labor.
Same as you I enjoy seeing all the great ideas all the members here have and all the inspiring projects.
