Who did I piss off??????
3,717
Man one thing after another, life is good,, HACK,,, grrrrrr ,,,, late charges for stuff I already paid, I know cause I checked the back and checks cleared, ran over the damn sundial chewed it up and I have no idea where the arrow went,, nothing flat,, yet,, Winds knocked some Beatle killed pines down, so nice day chain saw time,,, nawww this little POS Stihl MS211 has never been right from day one, shop says nothing wrong,, no start,, ok check plug, no spark, check gap on module, of course you have to take all the plastic off first, it is laying almost on the fly wheel OK one business card later set between 15 to 20 thousands should be good,, check plug gap .020 good,, put it back together and pull and pull and do I get a spark,,, nawww ,,, then maybe a spark. maybe not. OK let try it hope upon hope,,, nope not even with juice ,,, nada. I never had problems with the Husky or even the old 10 10 Mac pro. OK Im done venting, I just hate to order a spark module and not be the problem, yeah I know its like 60 bucks on line but still.
DaveFromMi
L3901 RCR1260
Apr 14, 2021
630
578
Indiana
I was having problems getting consistent spark on an old Honda rototiller during daylight hours. When the area was dark, I could see better consistent spark. I probably have a gummed up carb.
arml
B5100e BX2200 JD455AWS G1800
Jan 27, 2022
209
230
Pennsylvania
Around here.... nobody wants a 211....they go with Echo, I agree with that.
3,717
The 211 was a quick need buy, good for small limbs and light stuff. But I need one that is going to pop off when I need it. Hate spending 600 + bucks on another saw
5,105
Stihl, battery powered saw!
dlsmith
BX2230, LA211
Nov 15, 2018
1,253
817
Goshen, IN
I had a Troy-Bilt 4 stroke weed eater for 10 years or so, always ran the fuel dry in the fall and checked the plug so it was ready for spring. It always started after a few pulls and ran great. A couple of years ago in the spring, I gassed it up to do some trimming and it refused to start. Rebuilt the carb, replaced the plug, replaced the ignition module, checked the valve lash and checked the compression. No matter what, it wouldn't start. It had spark, but wouldn't fire, even on ether. When pulling the rope start, it acted like the timing was advanced. Pulled it apart to check the flywheel/crankshaft key, it was fine, and it looked to be in time. After about 10 hours of futzing with it and a lot of cursing, I gave up and bought a new power head.
Sometimes I hate those little engines.
Toyboy
BX2230D - RCK60-22BX - BX5450
May 18, 2010
658
995
Hayward Wi
Boy, sorry to hear that. I've got the same Stihl 211 and it's been my go to saw for several years. The only difference, mine was given to me strait gassed and I had to rebuild it. Could you have a short in the kill switch wire or plug wire??
