Which BX25 is it?
stevewhitts
BX25D
Mar 5, 2025
Maryland
Just bought a used BX25 and I'm trying to figure out which BX25 it is. The hood says BX25. The ID label says BX25D (label with serial number). The brake pedal is on the right-hand side, tach & hours are one digital gauge, temp & fuel are analog gauges and a couple of lights (glow plug and a couple other). It came with BT601 backhoe and the loader is a LA240.
Any idea which model I have?
2,672
love to see some pictures!!!!!!!
does it have arm rests?
2,672
the bx2360 series had brake pedal on right - 70 series moved pedal to left
6,039
Isn’t the BX25 and BX25D the same tractor/loader/backhoe model?
Seems like it was similar with the BX23/BX23D and the BX24/BX24D….
I may be wrong; just thought they were synonymous.
2,672
They are more or less the same..........
I think - and yeah I could be wrong - the "D" added armrests! and something else .......
ok - I cheated , looked it up
" such as a revised dash layout, a higher steering wheel, and a relocated brake pedal. "
Mountainman
L2501, B7100, B2710 B21, B1750, B2400, B7200
Jul 10, 2022
314
120
Attalla Alabama
mossycreekoutdoors.com
Bx25 is a 60 series and bx25d is a 70 series. Only real difference is the brake pedal moved to the left on the bx25d. Your panel isnt really a good guage as the original panel likely failed and was replaced with the updated version which had the digital tach on the right side as you have. Its confusing because the bx24 also has a label of bx24d but hood says bx24.
Bx24 bx25 and bx25d are essential the same tractor. Bx24 had the plastic fender and hood, bx25 same thing but changed to metal hood and fender, bx25 again same tractor just moved brake to left. There are a few trivial things such as armrests, rops, etc as well
7,782
Give me the serial number and I'll tell you exactly what it is.
There is actually 3 versions of the BX25's
BX25
BX25DLB
BX25DLB-1
