What Bucket Models are compatible with the BT1100
5,064
i’m looking to see what buckets would be compatible with the BT 1100 backhoe. Any information will be very much appreciated. Thank you.
Bucket choice matters greatly what BH bucket connection system you have on your L48TLB.
The Kubota Quick Connect system has a very different connection than the standard Kubota pin on BH buckets.
If you have what is called the Kubota quick connect system, you have the K7770 connector on your machine, and that is a very handy system.
The two different bucket attaching systems use different Kubota buckets that are not are not interchangeable.
OntheRidge
Nov 1, 2020
376
437
I have an L47 with the BT1000, with the quick change bucket. Not the hydraulic quick attach, but pull 1 pin and roll out of the bucket.. I found the buckets for the KX-40 series excavator compatible. Many thanks to the folks at Rhinox for helping me figure it out. They were awesome with detailed drawings of pin spacing. Hope this helps you out! Best of luck.
5,064
There is a hydraulic quick attach?
5,064
No quick attach as of yet but my better half is looking into one.
The Kubota K7770 quick coupler is about $2,200, if you can find one.
Kinda pricey, but really handy.
You should never expect to find a used one, as the coupler is so unique that likely no one would ever intentionally remove it
