Valve stem repair without tire removal?
Farmcat
Bx2360
Sep 19, 2024
Georgia
Howdy folks, 1st Post here regarding my first tractor a bx2360.
Last weekend one of my front tires lost pressure, no big deal, cleaned out the bead and refilled it.
Since I had the air pump out I decided to check the rest of the tires.
I was trying to bring the rear up from 10 psi to 15 and the metal threaded part of the stem shot out from the rubber part and I discovered that the previous owner had filled the rear tires with some sort of terrible tasting liquid.
I put it back in and currently have it holding in well with a tiny clamp.
I've never seen this happen to a valve stem before, I'd rather not drain and have to remove and remount the whole tire to fix it properly.
What do y'all think?
AM28
Bx2360
Jul 7, 2024
106
125
Socialist WA State
I am very good at replacing valve stems without removing the tire. My wife has a bad habit, short Asian girl, of using the wheels and tires as a step to get up to our boat when it’s on the trailer. I have had to replace three valve stems this summer because she stepped on them :cautious: I just break the bead on one side, push it down past the valve stem, and replace the valve stem, pretty simple.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,314
1,747
Western MT
If the rear tires are filled, they only have a small amount of air in them. Rotate the wheel so the valve is at the top and jack that wheel up. It shouldn't be a big deal.
