Sunshine L1-22 DT Parts Diagram
Somerfield
Sunshine L1-22 DT
Oct 27, 2024
Melbourne Australia
Hello. I have an older L1-22 which here in Australia is regarded as a 'grey' import, so not much help from the local Kubota dealer. I have an oil leak in the front right wheel assembly - probably a bearing or a seal - but would dearly like to get my hands on a parts diagram with part numbers. It looks like the tractor serial number is 54846. Everything is in Japanese but this was the LICD number on a blue plate on the lower part of the engine block behind the left front wheel.
Any help is much appreciated.
1,342
See if you can locate an equivalent model. Sometimes there are two models that have to be used for different parts of the tractor.
See this thread. You may need to read through several posts to locate the lists. Some of the links have gone bad but there are PDFs further down.
Good luck
