I started a new thread to emphasis a new question.
I have a new battery with 13.6 volts, new cables and ends, all fuses are good. Ordered new safety switches for clutch pedal, PTO and HST pedal sensor. Seat switch is OK.
I am now searching out the other possible culprits using using the wiring diagram. I am trying to locate the Engine Stop Solenoid, Starter Relay, ECU, and seat tilt switch.
In the attached photo of the relays under the dash instrument panel I need to know what each of the four relay units do (e.g., their functions).
I have a full service manual and wiring schematic but no labeled images of these relays. Which is which?
I know one is the starter relay and wonder which is the fuel shut off circuit and what the rest are. Any ideas? Thanks !
The image of the broke down Kubota on the steep hill is simply for sympathy purposes
