smog pump for boost
akghound
L275 Kubota Tractor
Dec 29, 2011
Montana City, Montana
Not too long ago, on one of the few forums I attend, there was mentioned using a smog pump to boost intake on a gas engine. I would like to know more about such an idea but can't find the thread. Do any of you guys know how to do this?
Ken Gardner
PS: I am posting this on the other forums too. So if you keep seeing this it is because you are following me. :D
Kubota Newbie
M4500, New Idea Cut-Ditioner, JD 14T Baler, IH "Plow Chief" plows, Oliver Rake
Dec 28, 2010
533
81
Mount Vernon, Ohio
Well, it probably will not create enough air volume. The smog pumps (most of them) are just rotary vane pumps and will not move enough air to really create any boost on a small diesel. Belt driven "Blowers" generally come in two flavors "roots type" with inter meshing rotors and centrifugal whereby a large impeller similar to a turbo impeller is driven at high speed by a gear set in the blower. Both move a very large volume of air which is necessary to create the "boost" you want.
