I have claas disco 32 hay mower i am hooking up to my 108s tractor. my question is this i have it hooked up to the b port of the float and everything seems to work as it should. The mower dealer said that it should be put into float when the hay mower is down. In the instructions for hooking a single acting to the float valve says to not put it into the dentent for float as it will overheat the transmission fluid. I am not sure if i am misreading this or over thinking it. Any help would be appreciated.
Thsts an interesting question and I am not 100% sure I know the answer. AFAIK that tractor is an open center fixed displacement system and the remotes are DA tandem center parallel sections.
So.....
When any DA valve is shifted to lower position (pressure down) and only one outlet is connected to the implement you are deadheading the pump and the relief against the unused outlet. Thats what you want to avoid/minimize.
When the valve is shifted to float both outlets are connected to tank and the implement will lower under the force of gravity just like any single acting valve. The cylinder is free to move in both directions and the implement can follow ground countours.
Now the less than 100% part. AFAIK when the valve is in float the incoming pump flow is not blocked. It is flowing freely through the neutral core in the valve and out the power beyond port just as it does when the valve is in neutral.
Based on that I dont see any potential for overheating when locked in float. There is a very real potential for overheating if the valve is locked in pressure down.
Are you sure you read that right?
