Hey guys, could use some more advice.
If you will notice the pictures of the frame bolts on this thread
- I have hoisted the engine
- Stud bolts are removed
- Front frame bolts are all removed
- Removed the rear frame bolts (the four bolts inside the orange paint)
- There were two bolts on the engine that looked like it was helping hold it against the clutch housing - I have removed those too
I cannot get the front of the tractor to separate from the engine. I have it supposed on a wheeled jack. I have disconnected everything that I know. I had multiple guys tugging on the front last night and it will not come free from the engine. Obviously I need to slide the front of the tractor free so I can then slide the engine forward off the clutch and then lift it out.
After removing the studs, the front remaining six bolts, the rear eight bolts (ones in orange), and two bolts on top of the clutch housing that looked like it was holding it to the engine block, I have done all I can see to do.
Any advice? Anyone know what I am missing?
