When talking engine blocks, is a D902 a D902? For example, could I put one from a generator or a mower in my rtv?
Thanks,
Matt
Thanks,
Matt
That's a good point. I need to dig into this a little more, I just thought about the hydraulic pump. I can't imagine a light tower having a spot for one to bolt up. A guy 6 hours away from me has a couple for cheap, but that doesn't help me if it's not going to work...Not necessarily. Different applications may require changes to the mounting points, orientation of external components like air intake, pulleys, etc. Same basic engine with mods for specific uses. I think there are subtypes that identify factory versions of these motors.
Ok, so essentially I just have to transfer parts between my engine and the replacement?There is no difference in the blocks or heads.
The difference is in the governor setup and the speed control.
