Rock Bucket
Robert Franklin
BX-25D with LA240A
Apr 17, 2025
Charlotte NC
I am looking to get a rock bucket for my BX-25D with LA240A. I was asked by one vendor for size of mounting plate. I have no mounting plate. Are there any rock buckets out that will fit without a mounting plate? If not any recommendations on a mounting plate.
Thanks
Robert
8,190
No you would have to add SSQA to get a bucket to fit.
But you really don't have enough lift to use a rock bucket on that small of tractor.
John T
2017 BX23S
May 5, 2017
1,017
480
under a rock
YES.
Redline makes a rock bucket with Pin-on OR SSQA mounting.
I have the quick connect version on my BX23S
Made in USA !
John T
2017 BX23S
May 5, 2017
1,017
480
under a rock
Another thought (opinion) on rock buckets.....
lifting capacity is not a huge concern.
Rock buckets work best when you take small bites.... shake the bucket a bit... then dump.
load too much material and it will clog.
Especially if it has any moisture... dry stuff is more gooder... of course.
This depends also on tine spacing... I would suggest 3" over 2"
rock bucket works good for handling firewood also...
armylifer
Mar 26, 2013
2,101
850
Thurston County, WA
I have this rock bucket and it works very well on my BX1860. I have attached the link to the pin on style but he has other styles too. If you have any questions you can call and talk directly to the owner of the business. His name is Tony.
Here is a picture of my rock bucket in action.
