repair
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,139
138
Hardisty, Alberta
how to replace belly pto seal
Drain the oil. pry the old seal out and carefully tap in the new one. Then refill the oil. The seal has a flange on it that you can easily get a screwdriver behind to pry it out.
4,635
Put it onto a trailer and take it to the dealer for service. Just tell them " replace belly pto seal" and I am certain they will understand what you want done. Give them your name and telephone number, and turn and walk out.
Shadetree605
kubota b2100
May 1, 2022
212
100
north little rock, ar
if it's anything like the mid pto seal i have on my b2100 ?, i just pried the old leaking seal out, tapped new seal right back in. i did not even bothering to drain the hydro oil, i was quick !, yes..i had some hydro oil drain out ?, but it was not much, least not worth worrying about to drain all of it out. fairly easy task, and it sure beats taking it to a dealership.
