Repair of the hydraulics of the rear arms of Kubota aste A15
ovesnyvk
Kubota aste A15
Mar 27, 2025
Czechia
Hello everyone here on the forum. I own a Kubota Aste A15 and I have a problem with the hydraulic pressure that controls the rear arm of the tractor. The pressure goes to the distributor, but from the distributor to the piston no longer just a weak stream. (Is oil supposed to go to the piston even when the lever is down? Should it have a bypass back to the transmission. ?
. Rozebral jsem to, protože mi odpadávala ovládací páka (závada byla někde jinde) a teď nemůžu dostat tlak z rozdělovače na píst. Přikládám foto. Má někdo lepší schéma než já nebo to někdo opravil? Díky) jen slabý stream
8,005
Hello everyone here on the forum. I own a Kubota Aste A15 and I have a problem with the hydraulic pressure that controls the rear arms of the tractor. The pressure goes through the distributor, but not from the valve to the cylinder. I took it apart because my control lever was falling off (the fault was somewhere else) and now I can't get pressure from the distributor to the piston. I'm attaching a photo. Does anyone have a better diagram than me or has anyone fixed it? Thanks
