removing grease
tcalvin48
B2650HSD, LA534 FEL, BH77 16" bucket,thumb, WG24, BB2560, WC68, RCR1860
Aug 22, 2019
50
Dresden, Maine
Gave a quick look and didn’t find any recommendations so I’ll ask. After years of lubing FEL and backhoe I have a lot of grease build up. I would like to clean it up a bit but not sure what to use as a cleaner. I’m afraid lacquer thinner might hurt the paint and don’t want to try it without hearing it would be okay to use. Looking for suggestions, how do you clean the grease build up from around fittings?
Tom Stoltz
in Maine
Scm
BX23S
Sep 28, 2024
68
54
Missouri
I use my power washer and grease it up right after.
Be careful it takes those cheep labels off too.
I'll wait for some replies to find out if I'm doing it wrong.
L35
Jun 13, 2010
563
485
CT
I use an old tube sock or rag soaked in diesel fuel. Wear disposable gloves!
Tughill Tom
B3200
Dec 23, 2013
1,280
1,527
Turin, NY
Just finished cleaning up mine this Moring. I use a bit of diesel on an old paint brush, rubber gloves, a really thin long screwdriver and lots of rags. Took me about 2 hrs to clean and regrease.
tcalvin48
Aug 22, 2019
50
Dresden, Maine
Diesel fuel, great, thanks. I have some old kerosene I need to get rid of, I’ll use that… basically diesel I guess. Unless you think it might leave a film.
Tom Stoltz
in Maine
5,110
Tom Stoltz
in Maine
ABSOLUTELY NO LAQUER THINNER!
Lacquer thinner WILL remove your lovely orange paint,....... as well as the grease.
Diesel fuel or kerosene, are best used.
A HOT pressure washer is also good, but is NOT good with cold water.
Cold water wash simply spreads the grease around, to other areas on your tractor.
1,678
You might need to use a “putty knife” to get the clods of grease off. I would use a plastic one first to avoid scratching the paint.
6,230
I thought we were suppose to leave all grease buildup in place and let harden. After years of build up just paint over it. That's what I see at auctions all the time.
Reactions: 8 users
6,286
Sounds foolish, but I'd rather see extra grease on equipment, than a lack of it.
Same with equipment that's obviously been pressure washed before a sale.
That said, I've given up coffee. So all I buy at an auction is a hot dog anymore... ;)
I greased the loader on my BX today. Was thinking about this thread.
I cleaned some of the extra grease off, but not too much.... ;)
6,230
Hey, the coffee if better for you then the hotdog!!
bbxlr8
Mar 29, 2021
418
276
Eastern PA
I use decent paper towels, both dry, then add Simple Green / purple cleaner as needed. Sometimes old rags, which I then toss. In my experience, Simple Green will generally not mess up your paint or lawn if it runs off
Speed25
L2501(sold) - BX25D
Apr 23, 2024
190
257
NC
I've got gallon cans of WD-40 from previous projects and I'll just soak a paper towel or rag, and wipe up excess grease. Afterwards, I'll do a normal greasing of fittings.
8,178
The zep purple cleaner is really good too, but hard on painted surfaces and aluminum and skin.
So I only use that on steel parts with gloves.
6,286
Yes, the Zep purple is good stuff. It has it's limitations as you mention.
I've used it quite a lot but need to thoroughly rinse when done to avoid paint issues.
