Needing some input/guidance on rear hydraulics if there is anything I may be overlooking.
I currently have one rear remote on my M6040 that I use with a hydraulic top link.
I just purchased a rear blade with hydraulic tilt and angle adjustments. Also purchased a box blade with hydraulic scarifiers.
So either way I will need more rear remotes. Dealer I purchased the rear blade from said each additional remote was $1,500 for my tractor. I can stack up to three on my model. Will definitely be shopping around price wise if I go this route.
Would I be better off adding two additional factory remotes or going with a hydraulic multiplier running off my current remote? Looking at the Summit hydraulic multiplier kits.
What other implements are there that would need multiple remotes that wouldn’t work with just a hydraulic multiplier?
