My new-to-me L3940 is at 600h (I got it at abt 520). Because I've no way of knowing if the major 400h service was done I'm doing it now, including front axle, engine oil, HST fluid, and coolant.
Thus far, none of the capacities listed in the OM are close to correct.
Front axle capacity is supposed to be abt 7qt; fluid came out the check hole at about 5 qts added ( this with long drains and use after filling).
Engine oil should be abt 9 quarts with a filter change; I'm overfull after adding 7qt.
Coolant system should be 8 qt, but refilling after a drain takes less than a gallon.
Is this typical? The axle and engine have enough fluid, but not knowing really if there's another gallon of coolant in the block will make getting the final blend correct sort of challenging...
Thanks in advance for any insight!
