No. 4 holder is weeping (has been for months if not years - previous owner mentioned it), and I suspect no. 3 is just starting to as well - see photo. From the numerous threads on the subject I've decided to fix it myself (it's been wonderful reading the contributions of people on this forum and elsewhere over the years. You guys are awsome).
There seem to be only 2 options to fix the leak: (a) get the injector lines off and crack open each delivery valve holder and then re-torque or (b) pull all the lines off, pull all the holders and replace all the gaskets.
My questions are:
1. How successful is (a) above, usually. Should I bypass it and go straight to (b)? The attraction of (a) is less disturbance, but if it doesn't work I've got to do (b) which is more distubance of the fuel system because I've had to pull the lines of twice. I'm paranoid about dirt getting into the system (have been ever since seeing a video by Cummins about the damage dirt does).
2. On this pump, what is the "Gasket, deliv. valve" made of? Part number 15221-51240. The options seem to be copper ring, or rubber O-ring? Can someone confirm the material please?
Thanks in advance for your advice.
Sorry about the parts diagrams being so small - not sure how to fix it.
My questions are:
