Hello,
I am a bit confused by the oil dip stick in the engine. It does not even look close to the picture in the manual. It is also fairly loose in the block, this could be wear or possibly it is the wrong dip stick.
When I did an oil change today I filled in exactly 3l as per manual and now the oil level is up to the blue arrow. Is the minimum really the orange and the maximum the blue mark? Even considering that the stick is at an angle I find the distance a bit too big. There are two more marks in the middle but I think those are part of a number.
Can anybody confirm / deny that this is the right dip stick and where the minimum and maximum marks are?
Kind regards,
Hugo
Kind regards,
Hugo
