Question about Woods Belly Mower for B6100D
Lake Marina
B6100
Apr 25, 2023
Im selling the Woods 348 Belly Mower that came with my (2nd hand) B6100D and unsure if I should remove the vertical bracket that has the toggle switch mounted to my tractor. Im selling the deck cheap so Im thinking Id rather just leave the bracket in place.
Questions:
1) Assuming clutch goes with deck is it fairly simple for whoever buys the deck to add there own toggle switch?
2) Is there any other attachments I could buy/use if I kept the bracket and clutch or is the clutch Woods specific?
3) Will this deck only work on a Kubota and if it will would they need the clutch or would their manf/model typically have their own?
Thanks.
Edit: to break out the questions and add the bold text for clarification.
1,221
The vertical bracket is part of the tractor that had the switch added. The wiring and switch should be connected to the electric clutch of the front mounted PTO. There should be a power supply wire from the tractor to the switch that will be removed and the tractor end removed or insulated.
