Hello,
I have a B2761 quick hitch/subframe I use for a front end snowblower attachment. I made a bone-headed mistake this year, when I swapped out the belly mower and attached the subframe, I forgot to attach the driveline to the mid pto shaft and drove off. Needless to say it ben the driveline pretty good, and in two directions (not easily straightened).
Although the part # I need on page 3 of the attached parts manual is 70060-01147, it would be easiest to replace the entire driveline, part # 70001-00623. Best I could find OEM is nearly $400 for the driveline, and $250 for the one component.
Wondering if anyone has found an aftermarket for this part(s)? Weasler?
Thank you.
Thank you.
