Power steering cylinder removal
farmboy24
G5200HST
Jan 13, 2024
E Texas
what is the easiest way to remove the power steering cylinder from an L4300DT? Need to have the seals replaced.
8,044
The easiest way:
Have some that knows how to do it, do it! :p
Second easiest is to unbolt it and remove it. 😉
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,020
1,660
WestTn/NoMs
What Wolfman means is
+ Remove the hoses, catch the drip
+ Remove bolt 220 and pull pin 200
+ Remove bolts 130 and remove cap/bracket 100. Note where washers are so they can be replaced correctly.
+ Lift cylinder off.
8,044
Couldn't have said it better myself! 😁
farmboy24
G5200HST
Jan 13, 2024
E Texas
Lord knows, we need all the humor we can get in today's world.
Mainly what I was asking, can this all be done without disassembling the whole front end of the tractor?
8,044
Yes, on some models you need to lift the radiator to get the pin out.
