L4701, tires filled, but I need more ballast. I thought it would be great to put my 412 lb. forks on the rear 3ph, but I can't find any attachment options to do this. What do you suggest?
awesome but not in my budget. too bad I can't use my 400 lb forks in the rear. I can usually have my two brothers and their 500 lbs of weight ride the back but you know, the virus.
Tractor Supply has a carry all for $150 with no shipping(pick up at store). I ordered that. Shame I can't easily use my forks in the rear (that's what she said), but this should work. thanks.
I made my own 'carryall' using forklift forks, 20 years ago for the D-14. Used scrap steel and a buzzbox,so zero cost( forks were free...out of guv spec). it's been far handier than the loader,so I scrapped that. Will carry 1500# all day long but need some front ballast...
Titans got one like the one linked above for 400$. I love having the ability to put the forks on back. I built a carryall that I can take to the timber and drop off in seconds then I can use the forks to lift the logs to a good height to buck up. And yes the added weight is nice ballast and if need more just have a pallet with few hundred more pounds of whatever on it. A hydraulic top link helps.
