Offset flail mower for L3901
OldcrowP51
Kubota L3901HST, RCR1860 rotary cutter
Aug 18, 2021
45
26
Minnesota
How big of an offset flail mower can my L3901 handle before it gets unstable.
I’d like to cut the tractor width (5 ft) and as much off the side as possible.
I’m hoping 18-24”
Power wise I’ll be cutting tall grass with small saplings/brush.
I have a brush hog for the bigger stuff.
mcmxi
5,809
NW Montana
I’m hoping 18-24”
Do you have filled rear tires and/or wheel weights? The weight of your tractor will have an effect on stability. Take a look at the Del Morino Funny Super hydraulic offset flail if you want as much reach as you can get. The 132 has a 52" cutting width which is not quite the 5ft you're after but close. I have a Centurion Super 158 and it's a very good flail.
