New head causing increased exhaust & fuel consumption
Bill in the U.P.
L4630 GST
Dec 31, 2020
55
15
I had a new (not OEM) head installed on my L4630 (2300 hours) a few weeks ago. The old one was cracked and leaking coolant. Since the new head install the tractor seems to be going through fuel much faster. I keep the tractor in my shop building and when I start it and pull it out it leaves such a cloud of blue in the shop that I have to leave the door open for quite awhile before I can go in and do anything. Is there any reason for this that you know of? It seems to me that a new head would result in better operation (less fuel, less exhaust) nor more. I appreciate any ideas you might have about this. Thanks.
ctfjr
L3800HST
Dec 7, 2009
1,765
2,029
central ct
did they use the old valves? Is it possible the new head has bigger valves?
5,510
#1 Your going to need to do a compression test!
woodman55
L6060HSTC, RTV 1100
May 15, 2022
777
569
canada
How much blow by. I am just wondering if the coolant took out the rings/walls. A compression test will help tell the tale.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
585
188
Herald Calif.
As Wolfman said you will want to check the compression. Typically if an engine gets hot enough to crack the head it will take the spring tension out of the piston rings.
sitric
L2850DT Ferguson TO35
Jan 13, 2023
69
46
Very seldom does just doing top end, make a strong engine. I am assuming op didn't touch the bottom, as he didn't mention doing so.
Bill in the U.P.
L4630 GST
Dec 31, 2020
55
15
Nothing done except the head replacement. The back cylinder/piston was free of carbon build up, the other three looked "ok." I will get a compression test done asap.
IdahoNative
Kubota B7100D 4x4, non-HST, FEL 1630
Jan 12, 2022
114
46
Florida, central
My B7100 did the same thing after I reconditioned the 750D engine. I installed the head shim that came with the gasket set. I removed it. Ran great after that.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
856
1,011
Pittsburgh
That's the one that was sipping coolant. Possible zylinder wall damage there.
kubotafreak
Sep 20, 2018
1,022
375
Arkansas, US
Id pull the valve cover and make sure the head has valve stem seals. Or pull the intake to see if oil is leaking in. All the compression possibilities aside, oil smoke is cracked head, vss, and since it didn't before you can rule out rings.
4,966
1,688
do a compression test if you have the stuff to do it with
or pull the head back off and inspect the pistons. You said #3 had little to no carbon. That's an indication that #3 is not running properly. With the head off turn the engine over by hand until a #1 piston is at TDC. Measure how far the piston is out of the cylinder. Or down into the cylinder. Then repeat for #2. It should be identical to #1. Then #3. It also should be identical. If one is further down into the cylinder than the others that connecting rod is most likely bent, I suspect from coolant entry into that cylinder due to prior issues. I may be wrong but that is my gut feeling.
