need some help
Lee Wilson
L2605DT
Aug 11, 2009
Bend, Or. Deschutes
Yes - I am glade I found you -- anyway, we purchased a Kubota, 4 wheel drive (older) that we would like to obtain manuals both parts and service - where do we go for that info? Any info that will show us anything in particular we should know. It has the #s L2605 DT; V1502 - L and 26 PS. I understand that it is a 'gray market' tractor. We have been using it on our small farm and now it is in need of some repairs.
> The left front hub started to leak fluid (visual on the outside of the hub)-- we are assuming that the seal needs to be replaced. So how big of a job is this and how do we go about it? We will do the work..just need advise
> We live in Oregon - any good resourses for us??
> Any help will be greatly appreciated..
> Lee A. Wilson
Ob1kubota
M9540DT
Jul 26, 2009
316
Birmingham, AL
Welcome to the forum Lee! Vic one of our Moderators will see your post and probably come up with some ideas. I think this is an almost mirror image of the L2600DT V1500 three cylinder liquid cooled diesel engine gear tractor. We will find something to help you with stay tuned Sir...:)
Ob1kubota
M9540DT
Jul 26, 2009
316
Birmingham, AL
Ob1, how many of those seals have you replaced over the years!
I'm at a bit of a loss for a parts manual for the L2605, we'll have to do a bit of digging, but I'm thinking Ob1 may be on track.
Vic the only ones I've replaced had shockloaded spindles or cracked housings. They are the new type poly-carbonate seals with no preload on the seal retainer. If the leak is a mist I recommend a heavy gear oil replacing the UDT loaded at the plant for wet shipped tractors. Brake squawk no big deal compared to tear down ;)
Lee Wilson
L2605DT
Aug 11, 2009
Bend, Or. Deschutes
Thanks for the responds - I live about 5 hrs from our property - I get down to the project about once a month. The info you sent will give me a start. When I get back I will let you know what I have learned.
thanks
And 'May the Force be with all of you'
Lee
