MX5800 oil seal removal
anyan1
mx5800, disc,brush hog, grapple
Jan 13, 2019
Harwood, TX
I would really appreciate it if someone could tell me how to remove the oil seal (item 100) from the Front Gear Case (item 60). It appears the seal is held in place by a metal ring that is driven/hammered in on top of it. How in the world do you remove the metal ring to get the seal out???
Thanks for your help.
TerryKing
B7100HST-D
Aug 18, 2024
137
67
Topsham, Vermont USA
arduinoinfo.mywikis.net
Hi,
Most seals like that have a metal outer case and a resilient inner seal element. That is one unit, replaced together. Often a "hook" shaped tool is used to reach thru the resilient seal parts and grab the outer ring and pull the whole unit out. Often need to coax it a little from around the circle. Or a sheet metal screw is screwed into the seal or the metal ring to pull it out.
The replacement seal with its metal ring is pushed into place evenly with a flat board etc and a hammer.
See this.
And youtube of course::
A cross section:
anyan1
Jan 13, 2019
Harwood, TX
Thanks, Terry. I'll give the screw method a try. That would be a slick solution if it works.
BTW- the older version of this seal was two pieces. The new version is one piece. Not sure which I have...yet.
Appreciate your help!
anyan1
Jan 13, 2019
Harwood, TX
060 is the housing itself. Do you mean 100, which I call the "kingpin seal"?
Yes... Item 60 is the front gear case. Items 130,120,110, and finally the oil seal (item 100) are loaded into it. Then the Bevel Gear Case (Fig. No. F145xx) is pushed into all these items and Snap Ring 140 is installed on the shaft.
The Oil Seal has to be removed from the Front Gear Case before removing items 110,120 and 130. That's the point I'm stuck on. Sorry if I wasn't clear.
whitetiger
Nov 20, 2011
2,899
1,363
Kansas City, KS
The seal is a cassette-style seal, a seal inside another seal. The metal you are seeing is the protective shroud for the seal.
I remove them by driving a square pry bar under the seal from inside the seal and turning the bar that pops out the seal using an adjustable wrench
There will also be a sleeve on the case from which you removed it. It will need to be removed before reassembling the assembly.
This is the style of prybar I use.
https://www.amazon.com/DURATECH-3-P...d=1729043103&sprefix=pry+bar,aps,2186&sr=8-42
