M7580 Won't move
Annjen22
Kubota M7580
Dec 21, 2024
Cleveland, UT
Does anyone have an idea we might try? The remotes work but can't lift the blade on the 3-point hookup, and the tractor won't move. We've changed the hydraulic filters.
1,475
What remotes work and what do they do?
Is the fluid low or at the proper level?
How cold is it? Did you change the hydraulic fluid also?
It may be that water in the hydraulic fluid sump is frozen and may be blocking any flow through the system?
Any chance you can get the tractor warmed above freezing?
