M7060 question / idea
Roogle
M7060, 6ft flail, 10ft wheel scraper, 10ft wheel disc, ect
Dec 13, 2018
Herald, Ca
So, other than the cab being different, my understanding is that the M7060 and M4-71 are basically mechanically identical correct? So, my question is, anyone ever looked into add the De-Clutch button from the M4-71 to the M7060? When doing a lot of loader work it would be nice to be able to use the foot throttle and the brakes. Ideas?
Thunder chicken
M7060
Dec 29, 2019
295
119
Northern ontario
I thought about looking into that idea,I saw a kioti that a fellla had done this same idea on, and he liked it. If you had a wiring diagram, I don't see why it would be so hard to tap Into the wiring from the f/r selector as I believe it controls the same electric 'clutch' valve. If you try using the selector to clutch, it works but just isn't as smooth as using the clutch pedal even though it apparently just does the same electric switch, to me it seems it does allow you to modulate it a bit...
