M7060 hydraulic pressure
Fedup
270
88
Winchester
I'm currently working on this M7060 cab tractor. I don't have a WSM for it and was wondering what the hydraulic system pressure relief should be set to. Tractor Data .com lists pump flow at 11 GPM but doesn't give the rated the pressure. I didn't have a gauge with me today but will have a flow meter and gauges next trip. Hydraulics are definitely weak as it not only doesn't lift much weight on the loader forks, it won't even raise the tires off the ground. When the cylinders bottom out and relief comes in the motor hardly bogs down.
