M5040/M6040/M7040 clunking/gurgling hydraulic steering pipes – any definitive answer?
knightbaker
M5040DT, M20 FEL, Allis Chalmers 170, BCS 725
Aug 28, 2016
Hazelton, BC
Hi all, I have a recently purchased 2009 M5040 (300 hrs) that makes nagging erratic clunking/thumping/banging/gurgling noises in the hydraulic steering circuit most noticeable at idle. Holding the metal pipes, you feel pulsations in time with the noise, from the pump right through the steering controller to the oil cooler. I suspected air from a suction leak, somehow...
However, perusing old threads in this forum and others, it sounds like there are many similar complaints with non-cab M series from these years since day one (the first models with the hyd pump on the transmission I believe). Lots of tales of repeated service trips to dealers, replaced relief valves, pumps, seals, bypass valves, steering controllers, all to no avail.
Does anyone have anything definitive on this problem? Either a fix or a letter/service bulletin from Kubota saying not to worry about it? Or have you been running a machine making these noises for 5000 hours with no ill effects?
I tried contacting Kubota Canada and my local dealer, neither of whom admit to any 'known problem' (and it's a 1000km round trip to take the machine to be looked at). The hydraulics and the rest of the machine function great, I would just like to put my mind to rest on this nagging noise. Many thanks!
6,172
If you think it's sucking air, check the suction line, common issue is a cranked or split rubber hose.
Tx Jim
M7040 HDC-1,JD 4255,Ford 6700
Apr 30, 2013
1,199
128
Coyote Flats,Texas
My '11 M7040 HDC-1 that I bought used 2012 with 137 hrs on speed-hour meter made hyd clunking noises. Either the clunking(gurgling) noises have dissipated or I've adapted my senses as I don't notice these clunking noises now. Speed-hour meter shows 1375.3 hrs.
knightbaker
Aug 28, 2016
Hazelton, BC
Thanks. The suction line on these machines is only a 4" long metal elbow from the dual filters in the tranny housing to the pump with O rings on both ends. It sounds like these were the first years the pump was mounted on the transmission, and according to speculation in other threads an engineering flaw causing some kind of cavitation or irregular flow with no apparent fix (and supposidly only on the non-cab models)
It sure does sound like air to me, but precious view places air could get in. Oil level is good, filters clean and tight (same issue before and after changing fluid and filters), O rings on suction tube fine. I'm hesitant to rip the pump apart to change the seals when is sounds like that has been tried by others to no avail. If the shaft seal on the pump is leaky, would it suck air or blow fluid?
6,172
Normally if the shaft seal is leaking it would blow fluid, But let me do a little more research on the pump.
What exact model do you have?
knightbaker
Aug 28, 2016
Hazelton, BC
M7040Josh
M7040
Wish I would have came across this forum earlier. Has anyone found a fix. I’ve noticed this hydraulic gurgling noise on my M7040 and have been trying to pinpoint it. I can feel it pulse in the cooler lines and back at the line on the pump. Also looking through the rear fill cap the fluid does bubble a bit. First thing that came to mind was to check the suction side, so I pulled my pump and checked suction O-rings. All o-rings were good. I had the pump out and decided to check it next. All seals looked good and so did the pump besides normal wear. Waiting on a seal kit and putting it back together.
knightbaker
Aug 28, 2016
Hazelton, BC
Wish I would have came across this forum earlier. Has anyone found a fix. I***8217;ve noticed this hydraulic gurgling noise on my M7040 and have been trying to pinpoint it. I can feel it pulse in the cooler lines and back at the line on the pump. Also looking through the rear fill cap the fluid does bubble a bit. First thing that came to mind was to check the suction side, so I pulled my pump and checked suction O-rings. All o-rings were good. I had the pump out and decided to check it next. All seals looked good and so did the pump besides normal wear. Waiting on a seal kit and putting it back together.
2 years on now on my 2009 machine, and still the same issue exactly as you describe. My theory is an engineering flaw that froths up the fluid (from the return lines?) and those bubbles make a racket in the narrower gauge cooler/power steering pipes (cavitation?) but are not noticeable in the main hydraulics. My chosen solution is to always wear my hearing protection around the tractor, and the noise doesn't bother me at all!
M7040Josh
M7040
Just an update since I resealed the hydraulic pump. I saved the hydraulic fluid since it I just recently serviced it, but changed both filters. The tractor does not make the gurgling noise from the hydraulic system like it did before.
knightbaker
Aug 28, 2016
Hazelton, BC
Thanks for the update Josh, guess I'll order a seal kit myself. Is it a fairly straightforward job? I had made the assumption that a leaky pump seal would likely blow fluid, rather than suck air...
JGraves
2008 m6040f
Jul 7, 2024
Charlottesville VA
Sorry to revive an old thread. Long time lurker but my first post.
I recently bought a 2008 m6040f 2wd no FEL. Tractor is very clean and has 900 hours pulling a hay rake. Tractor ran fine for the first 15 hours. All of a sudden I am having very similiar issues as to what is described in this thread, except my steering begins making the mentioned sounds then gets hard spots to the point I can barely operate the machine. Once this happens, the 3 point barely lifts the arms up with no attachment. At first start up it all seems fine until I raise the rpm and begin moving the steering wheel. I was told my pump is bad, but it sure feels like air to me and I find it odd it doesn’t have issues right out of the gate. I have changed the fluids, filters which didn’t help at all. Any insight would be greatly appreciated. I thought I’d post here since my issues are very similar, just a little worse than what others have said!
