S Sam Thornton New member Equipment M126X Sep 13, 2024 1 0 1 Monticello, Ga. 31064 Today at 2:45 PM #1 Spilt tractor to rebuild fwd and rear clutch packs, put back together won't crank, have code EN-ENG o dash. Have power to CRS relay, can ground terminal that goes to ECM and will crank and run, remove ground to shut off.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 29,645 5,863 113 Sandpoint, ID Today at 5:46 PM #2 Look at the WSM, sounds like you have an issue with a safety switch, or control input.
