Lugs and lug bolts?
marrmanu
B2620 3pt chipper, box blade, post hole auger, custom 3pt chain box with hooks h
Jan 16, 2021
117
90
usa
Just picked up a BX2370 and see its got lug nuts and lug bolts on both rear rims. Each located in the same pattern.
Any Ideas?
Speed25
L2501(sold) - BX25D
Apr 23, 2024
176
239
NC
Standard on all the BX models I've seen. The studs/nuts make things easier to mount loaded tires, but I don't know why the bolts are there.
1,577
If you have only two studs, you can line up one hole to one stud and get the wheel onto that one stud, and probably get the nut started onto the stud. Then you can raise or lower the tractor and get the second hole to line up with the stud and get it on. Then the other holes will be lined up to put the bolts in.
If all were studs you have to rotate the tire to get them all aligned at one time. Not that easy even on a car.
marrmanu
Jan 16, 2021
117
90
usa
Thxs, that makes too much sense.😆
