Hello, my barely used (150hr) LA271 has a new phenomenon when I try to use the controller to lift the bucket. As I move joystick down to lift bucket, it lifts, but at full joystick deflection, lift stops. I have heard this can be related to 3 point hitch pressure relief valve? Its a B7300 tractor, and a backhoe is fitted. I cant tell if my 3pt is full up to the point of triggering relief valve, but I have tried raising and lowering it while trying to raise and lower FEL and have not noticed any observable impact. I may take off backhoe to see if problem goes away.
Otherwise, I have removed quick disconnects, cleaned/lubed, checked for blockages, etc. Seem to be OK. I have not tried swapping lift with tilt to see if problem follows hoses to the other function....I assume it would, but I have not tried.
Any ideas out there? It is frustrating trying to use it this way.
