Loader for bx1850v
8,152
You have a BX1850D not bx1850v
There are 2 loaders that fit it.
LA203 and LA240
Both are going to be incredibly hard to find just the loader.
You would be better off selling what you have and buying a model with a loader already on it. ;)
Mountainman
L2501, B7100, B2710 B21, B1750, B2400, B7200
Jul 10, 2022
341
127
Attalla Alabama
mossycreekoutdoors.com
The la243 and la344 loader will also work on your bx1850. If your tractor is not loader ready with the valve and joystick already on it you'll have to get all that as well. The hydraulic steel lines from hydraulic block to valve are shorter than the bx23xx or bx26xx as the chassis is shorter. I have valves and joysticks. La344 youll have to remove the hydraulic plate and put quick disconnects on the hoses. None of these loaders are easy to find though
