Loader BX24 Hydraulic Leak
Covered.Wagon
BX24D
Oct 29, 2018
Wappapello, MO
My BX 24 loader valve leaks. The leak is at the Plugs for the spoolers. My WSM only identifies them as "Plugs" (#15 & #8), the parts breakdowns that I have found (Messick's and Coleman) only identify them by letter (G). The image below identifies tham as assemblies (#20 & #30). But no repair pats listed.
When I operate either the curl or lift functions, hydro oil spews out the ends. Not a lot of loss, but it gets messy. HELP! I need to identify repair parts to solve this issue.
whitetiger
Nov 20, 2011
3,027
1,483
Kansas City, KS
The seal kit is #50. It includes D,E,F,G,H
Are you sure this valve in the picture you put up is for a BX24D? It looks like the valve for a BX25D, see pdf.
jwdoan1998
BX24D, belly mower, brush hog, backhoe, FEL, llandscape rake, box blade
Dec 2, 2018
Wappapello, MO
I'm not sure of the picture, but my narrative is accurate. The part #50 that you reference as a seal kit does not show on the parts breakdown for the BX24 as being a seal kit. It show is as being a back up ring. Do you know the actual Kubota part #?
whitetiger
Nov 20, 2011
3,027
1,483
Kansas City, KS
Part #50 is the seal kit for the 2 spool valve that you posted a picture of which I am pretty sure is the 2 spool valve for a BX25D.
The BX24D 2 spool valve that I posted the pdf of does not offer a seal kit. You order the individual seals and o-rings. The part numbers are at the bottom of the pdf.
