I've had trouble getting my loader on my b2601 on and off since day 1. The dealer I got it from messed several things up on it themselves that i eventually had to repair myself, so i'm thinking this is something they screwed up in the first place that i've made steadily worse over time. After having several brawls with it, it's at the point now where the loader won't even sit straight on the ground. The loader itself looks straight, sits on the tractor fine once it's one, but the stand legs for it look like they're really not working right. As it sits on the ground, pretty much all the weight is on the left side one, you can actually rock the thing back and forth by hand, there's no weight at all on the right side one. In fact, you can just grab the right side leg and move it up and down, as there's no weight at all on it. Looking at the left side leg, it looks like it's not "deployed" properly, you can see that the silver bar on it is supposed to sit in the grove on the orange stand bar, but when fully deployed it sits like several inches forward of it and won't go down all the way to the point where it's resting on the bar. The other side looks like it would deploy properly if there was any weight on it, but the left side is propping the whole thing up so much it won't even let the right side go down anymore.
So i'm trying to figure out exactly what is out of alignment or bent here. Any ideas?
