I just bought an L4310, 4x4, HST with a LA681 loader on it. It's got about 2,000hrs total.
I noticed the front tires would move around a little before buying it and took a look. I found a couple tie rods that were worn out and figured that is the cause. Got it home and started into it and I found that the steering assembly moves around on the main shaft. The power steering unit is leaking too.
Here's my main question before tearing into this. Are the bushings (parts 070) likely culprits of the play on the shaft or is this more likely the shaft itself (150) or the bracket (020)? Diagram attached.
Is this a common issue? Is there a rebuild kit or are parts hard to find, etc...?
Thank you!
Thank you!
