L4060 dies again!
Mike Telesco
Kubota L4060
Oct 23, 2024
tech came out and Bled air out of fuel filter. It took awhile! Did couple days work with it with no problems . It sat two weeks and same thing. Looks like air is coming from the tank before the water separator. What can I do to get this started again? three years old and only 200 hours on it. Too soon to have these problems
5,520
curious, had a look online for the 'plumbing'.. I see 'rubber ' hoses.
if possible, replace the spring clamps with 'gear' clamps.
being 'young', I don't expect the hose themselves to be 'porus' but a clamp not putting enouhg pressure 360 around the hose to tubing could allow air to be sucked in
Mike Telesco
Kubota L4060
Oct 23, 2024
Where did you get this manual and how much is it. I got a finances. They want $500 just to transport the tractor to their shop.🙄
8,172
The fuel inlet fitting on older model separators (yellow) has know to be a problem.
see if yours looks like the first picture.
And see if it's loose in the housing.
Newer style fuel separator better fitting (blue).
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,331
1,529
Near Lancaster, PA, USA
Very long tale of a Volvo semi going several places and having several fixes - finally found a small hole in the white metal / aluminum fuel filter mount. It had a tiny hole hidden under some crud that appeared to be due to corrosion.
