L3901 e20 code
Richtrac1
l3901
Jun 25, 2024
I have a L3901 HTS with a e20 code, it keeps blowing the main ECU (+IG) 5amp only when I press peddle, I checked the wiring and have not found anything damaged .
4,333
Perhaps switch on pedal is internally shorting to ground ?
Would need to see wiring diagram but 'blowing fuse when pedal moved' should be real easy to troubleshoot.
4,970
1,694
the switch is either falling apart and shorting itself very likely. Check the hst switch, if it's coming apart it'll be pretty obvious. I've seen it happen a few times.
Richtrac1
l3901
Jun 25, 2024
the local dealer told me it sound like I had a short somewhere. What I found was the wire harness near the left side next to the exhaust was questionable. it had heat damage. I pull it apart and found a few wires that were spliced as you can see in the picture wrapped in blue tape. and had some damage to them. I was some what confused with what I found being I bought the tractor new and haven't had much service done to it. the wire that is apart was me starting to resplice the wires ,
so far it is starting and running great!!🤞the true test will be this weekend. I have a lot of grass cutting to do.
