Good evening everyone,
I just had a recent issue pop up with my Kubota L3800 HST and can't find any posts regarding the same problem. My tractor's PTO engages no problem when I start up my brush hog. However, after I disengage the PTO (to put rocks or debris in the bucket) I'm not able to re-engage it while the blades are spinning. I push the clutch down and slowly push the PTO engagement lever only to be met by a loud gear popping noise, I quickly eased off and did not try to force anything.
I always use the clutch when engaging/disengaging the PTO and ease off the clutch during engagement. Any ideas what this issue could be? The tractor's over a decade old but only has three hundred hours, I've never had this problem in the year I've owned it.
Thanks,
Casey
Thanks,
Casey
