Hi,
I tried to search for this but could not find it. The bulb size for the idiot/dash indicator bulbs is 158. The bulb is mounted in a quarter turn socket that just turns and comes out easily from the dash. The bulb is pressed into the socket. I would suggest using a rag or paper towel to pull the bulb out. They are a little snug and you will have to pull hard (just straight out, do not twist the bulb). Just press the new bulb fully back into place.
A little FYI, I found the bulb at Autozone but not at Walmart. It is probably a little less used than some and that is why Walmart probably doesn't carry it.
I hope this helps someone.
L3600GST
L3600GST
