A friend has a L3301 with the hydrostatic transmission.
The two lines with three connections shown in the attached pictures are leaking where the bolts hold them to the filter base/housing and the transmission housing.
We replaced six orings and started it up and immediately it blew out two of the orings at the filter housing top port.
However, I just used orings from a generic kit I had so NOT Kubota parts.
I think the line from the transmission is the input to the filter. Is that correct?
Anyone have any insight on fixing this leak?
Could a restriction in the filter cause the leak?
On a side note it is missing the bracket that supports the filter so, I think even with Kubota parts it the leak will reoccur due to the metal lines flexing.
I think the L2501, L3301 & the 3901 are all the same just with different power output is that correct?
