Hi,
Looking for suggestions to get a L3130 to start. I was running the tractor for a few hours with multiple starts and stops with no issues starting, until I turned on and tried to start it. The tractor made one click when the key was turned over. I tried it a few times with the same result. To try to resolve the issue, the battery was replaced, the ground was replaced. The area the ground was connected was buffed out to clean metal and the positive terminal was replaced.
I believe the issue is likely the starter, but before investigating the starter, should I be checking out something else.
Thanks for any input.
Chris
oh yeah, the isn’t engaged.
Chris
