L3130 HST PTO Pipe replacement
randy c
L3130, woods loader, box blade, squealer bush hog and rake
Mar 1, 2016
11
Covington, LA
What is the best way to replace the PTO pipe on my L3130 HST? I removed the broken one by removing the broken HST filter bracket and filter, 2 pieces of linkage next to the filter, the seat and base and still had to almost straighten the pipe to get it out. It goes over the transmission to the other side and terminates with a banjo fitting. I decided to check with the forum before I did major damage unlike the first time I checked with you.
4,949
Randy - trust me, I'm not the guy with your answer, but your description had me confused as to the part(s) you're working with/on.
Post a couple of pictures, might help get a quicker and better answer.
Best of luck!:)
5,159
1,845
Reminds me of replacing one of the hydraulic pipes on a B series tractor. There are 2 ways to do it. The correct way, and the shortcut way. The shortcut way is to pull just enough stuff out of the way to be able to bend the pipe around the HST links, but in bending it, eventually it will fail at the banjo joints The correct way is to remove the fender, floor, all HST linkages, brake pedals, other pipes and if it's got a loader, the loader frame. Much more time consuming but it's the only way to perform a proper repair.
I suspect this is similar predicament you're into. And the correct way would be to disassemble it enough to get enough access for replacement. I have an idea which pipe you're speaking of, and it's a pain to have to replace.
6,062
If you don't have it already I'll send you a link to download the WSM might help in ironing out what needs removed and how to do it.
randy c
Mar 1, 2016
11
Covington, LA
Thanks guys. Lugbolt, it is as similar as it gets. Wolfman, I got your WSM. Thanks. Now I just have to learn how to use it. I'm going through it page by page until I find something about hydraulic line or pto line. Is there a main table of contents or index?
Thanks,
Randy
