I bought a 3130 recently and shortly after I started using it I started noticing a knock that seemed to get worse as the tractor warmed up. I Figured it was a rod bearing and pulled the oil pan and the rod caps and everything looked ok. I then pulled the engine out and put new pistons, wrist pins and bearings in it. I expected to find a spun main bearing. I did find some wear but nothing really bad.
I put it back together and fired it up and within a few minutes the noise came back. I did not pull the cam, but the lobes looked good and the tappets did as well. I'm fairly confused. I've never worked on a Kubota before and its obvious I'm missing something. Could the injection pump, the timing gears, injectors or oil pump cause a knock that's sometimes more of a tick?
