L2650 Ignition Switch Connector
funkyyota
L2650
Mar 30, 2022
Evergreen coloration
Hi, I’ve been going through my harness trying to debug and repair some work on my L2640 4wd from the previous owner. I started getting into this to debug a few different electrical gremlins. In any case, I’ve tracked at least one issue down to needing a new ignition switch. After removing the switch I found it looks like there’s a faulty connection on the ignition switch connector that caused it to melt. I’d like to repair this, but I’m having some trouble identifying the connector. Attached picture for reference. Any help would be appreciated.
5,561
OUCH, lotta power went through the upper left spot !
If you have the WSM, electrical section, it may have a chart of 'connectors'. In the BX23S WSM, that chart kinda says who the MFR of the connector is.
If not, they look like 1/4 tab connectors, so 4 individuals could be used, just make a map as to which goes where !
5,409
2,104
you can get on corsa-technic's website, and likely find that connector or pigtail to repair it properly. If not there, look around-I bet it's available elsewhere. Waytek maybe?
8,377
Send @007kubotaguy a message he may have a harness that will have that connector.
funkyyota
L2650
Mar 30, 2022
Ha. Yea. I think this thing got a little toasty.
I ended up buying a big bag of similar connectors from Amazon. I thought they might be close enough, but turned out the little indentations in the corner were on the wrong side. They came with enough connectors I just reworked both sides of the harness. Things all set now! Now I’d like to get the electric fuel shutoff solenoid system working, but that’s kind of a back burner job for the time being.
Glarks 300Pcs 6.3mm 4 Pin Way... https://www.amazon.com/dp/B07Y4V1VTS?ref=ppx_pop_mob_ap_share
