L2502
Kaah_97
Wisconsin
I recently purchased a L2502and it need an oil change. Everything I have found has been compatible for a L2501 but nothing mentioned the L2502. Are they the same filter?
Also I was moving some brush and busted the nipple off of the fuel filter. I was in a pinch so I put on a in line filter to get by. Due to the crappy placement of the factory filter, I am hesitant to replace it and just keep the in line filter. Thoughts??
8,325
Both tractors take the same filters.
A inline filter does not provide that same protection as a canister filter.
A inline filter does not separate and store water that can be removed.
Replace the canister filter!
NorthwoodsLife
Oct 15, 2021
1,148
1,089
Wisconsin
My thoughts:
OP says: "Busted a nipple off of the fuel filter". ....
Remember please.... It is a small farm tractor. It is not a bulldozer or a Sherman tank. Cut or move brush accordingly.
Be well. Tractor on.
4,589
Maybe consider adding filter guards if concerned about a repeat. Might have to make a phone call or send an email to confirm compatibility with the L2502 as most stuff your likely to find will list the L2501.
Example (not endorsement): https://ded-conmetalworks.com/protective-guards/
